1990 EF D16y8 Distributor
Hi looking for some help on how to wire my D16y8 distributor for my 1990 dx EF hatch, converted to mpfi using the D16y8 Injectors will be using a P28 ECU using the speed factory OBD0 to OBD1 conversion harness. Ive found the correct pin out to wire the obd2 plug to the two existing DX dpfi distributor plugs my question is all I have to do wire them together and call it done? or do I have to additionally route two wires for the crank sensor like on the angel fire mpfi swap. Or is that a completely separate plug and I'm an idiot?
All help is appreciated thanks
rhdekhatchie
Jan 23, 2008 10:04 AM
ID_ten_T
Jan 15, 2004 04:17 AM
