The snap rings from hell?? - Lost Motion Assembly
Old Feb 12, 2022 | 05:53 PM
Frozti's Avatar
Default The snap rings from hell?? - Lost Motion Assembly
My LMAs are crusty and need to be replaced like right now. I have an extra set, I wanted to disassemble them so I can sand and clean the inside. I can't figure out how to remove these snap rings. I've tried like 10 different kinds of picks. They're just a basic wire ring, no way for a snap ring tool I don't think. Is there a trick I'm not aware off? It's a d16y8. Watch this video...
https://youtu.be/jd5ydNmdLkQ
I'm currently soaking them in chemical for as long as i can then soaking them in oil but I don't think it will do much.
Old Feb 12, 2022 | 09:06 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: The snap rings from hell?? - Lost Motion Assembly
Cleaning them out does nothing for any internal parts that may be rusted inside the LMA's... rusty internal springs are potentially compromised and should be REPLACED. You are wasting your time trying to clean them up.
Old Feb 12, 2022 | 09:18 PM
Frozti's Avatar
From what I can see they look brand new, no rust. Everyone I've talked to who has removed the spring, sanded and cleaned the casing, lubricated and re-installed has had great results.
Old Feb 13, 2022 | 07:56 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I don't know what that means, but if the metals are clean and shiny, it is unlikely that there is anything inside that would cause you any issue... if there is a lot of "crud build up" inside, I suppose this could cause some coil bind inside and create some operational issues. Lubricating them will be redundant... they are splatter lubricated during engine operation and the pocket that they sit in keeps some oil in them at all times.
imadigitalgod
Audio / Security / Video
Dec 26, 2009 10:27 PM
matttegra
Mar 11, 2005 10:57 AM
EFb18b
Feb 24, 2004 02:16 PM
Dan GSR
Jun 30, 2003 12:48 AM
