Need help with bolts
Old Feb 11, 2022 | 06:06 AM
mightjustdie's Avatar
Default Need help with bolts
Need the three trans mount bolts. Anyone have any advice or help?
Old Feb 11, 2022 | 07:16 AM
NukeNinja's Avatar
Default Re: Need help with bolts
I think those are M12 x 1.25. You could add the hole depths and mount thickness and come up with a hardware store alternative. But you might get better screws from a junk yard.
Old Feb 11, 2022 | 08:54 AM
spAdam's Avatar
Loved
Community Favorite
What car is this going into? 92-92 has the bracket on the frame rail with the mount on the trans, 96-00 has it the other way around as posted above. That's also an engine mount in the pic.
For a 92-95, OP needs a trans mount, plus all the hardware. Fasteners are all M12x1.25, can be found aftermarket but are hardened bolts and really should be sourced from the dealer or junkyard if possible. Same hardware for basically all 92-00 manual trans Civics.
If 92-95:
If 96-00:
Hardware is the same for either:
Old Feb 11, 2022 | 05:00 PM
found my bolts but i think you can help me with my next thing. I found a website for everything but cant find this diagram for the life of me. I have the correct mounts that was just by the trans for some reason
I need 14 in this image but I cant find ****
Old Feb 12, 2022 | 08:51 PM
88si92si's Avatar
Hit the junk yard
Tyler_EJ2
Transmission & Drivetrain
May 28, 2013 01:39 AM
jbpnoman
Dec 28, 2011 12:16 PM
1984eghatch
Sep 17, 2011 08:09 PM
lsvtek
Sep 29, 2008 11:45 PM
blanco617
Aug 13, 2007 03:22 PM
