Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Thinking about buying a new civic LTFT normal?
Old Feb 10, 2022 | 05:12 AM
CivicBoundProbs's Avatar
Default Thinking about buying a new civic LTFT normal?
Hello everyone.
I'm thinking about buying a new 9th gen si!
Always wanted a peppy civic.
Is LTFT at -14% on a cold start (i.e. go to the grocery store around the block,and start it after you get out), normal?
This particular civic has an exhaust mod that is an outlet before the muffler. Some kind of custom setup I guess.
I'm wondering if that will trip up the 02 sensor and make it run rich on startup.
This isn't the first time I've seen that sort of fuel trim on a k-series engine on startup.
It goes back down to normal after running it around the block relatively hard.
Thanks!
Old Feb 10, 2022 | 07:57 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Thinking about buying a new civic LTFT normal?
So, you are saying that your fuel trims (STFT and LTFT) are pulling fuel while the engine is warming up, and get close to zero once the engine is warmed up ? If so, then there is nothing to worry about at all. One could adjust some cold start fuel trim values to keep fuel trims closer to neutral, but you need a tuning solution to do this.
Old Feb 11, 2022 | 05:55 AM
Thank you.
It's LTFT only at -14%, after a quick trip around the block and after sitting for a bit.
STFT is at -3ish%.
That's what confused me.
After running it around for a while and hitting v-tec a couple times, it all goes back to normal -3-4% at both LTFT and STFT.
All other civics I've looked at were -3-4% always, regardless of how cold the start was, and what was going on.
Old Feb 11, 2022 | 09:03 PM
JRCivic1's Avatar
10 Year Member
Community Builder
There is a possibility that you may have a problem with the fuel pressure regulator in the pump assembly... this would cause a rich condition at or near idle engine speeds, however, fuel trims move closer to normal at medium and higher engine speeds. It is an easy fix... and a genuine OE FPR is less than $150.
Bluebull
Mar 11, 2013 05:31 AM
KN0C0N7R01
Oct 4, 2012 12:32 PM
8049710
Dec 7, 2011 01:15 PM
