90 civic EG hydro trans shift linkage?
Old Feb 4, 2022 | 12:38 AM
EllisEFsir-G's Avatar
Icon5 90 civic EG hydro trans shift linkage?
Hello, I'm in process of swapping an EG engine and hydro trans into my EF. I've already pieced together custom mounts and t bracket, and I've already fabricated my own reinforced pedal assembly bracket for the clutch master cylinder. I was just wondering if there is any information regarding how I'd get a shift linkage to work. Would it be easier to cut the EG linkage, mod the EF cable tranny linkage, or buy the overpriced $250 Hasport option? I've been doing a lot of research and this is the last thing that has me stumped on this swap. I really don't wanna fork over $250+ shipping unless absolutely necessary, but I will do it if I have too lol
Old Feb 4, 2022 | 11:43 AM
Hasport's Avatar
Default Re: 90 civic EG hydro trans shift linkage?
yes you could always cut and weld the EG linkage
hasport linkage is bolt in and 149
Old Feb 4, 2022 | 10:54 PM
Ok, thanks for the advice. I just remembered I have multiple EG linkages so I will give that a shot. But where have you seen an EF hydro D series shift linkage? I've only ever seen stock EF ones and EF b swap linkages. I felt like I really looked but so far I haven't been able to locate a custom hydro d series linkage on the internet. Probably worth it just to fabricate a linkage. If I mess up with the cutting and welding I will go to a shop and tell them exactly how much shorter I need it to be, shouldn't be too hard seeing as I'm about to attempt it myself lol.
Perhaps I'll be making a post about the finished product in 3 weeks from now after I fully swap the car with a full eg swap, d15b7 + hydro trans. I also have a z6 head laying around. It'll be perfect! I might be one of a very small handful of guys out there with a hydro d series sohc vtec EF Si I'm honestly more excited about this than my new B20B4 EG Hatch build I'm simultaneously building lol. There's just something about EF's.
Old Feb 7, 2022 | 07:35 AM
Hasport's Avatar
ah you are swapping in a dseries with hydro transmission into your car. i didnt realize thats what you were doing from your first post. second post cleared that up
the stock EF linkage will work. no modifications needed
Old Feb 9, 2022 | 09:16 PM
EE2bitsk's Avatar
you mean your clutch is hydro now, not the linkage lol. hush performance used to make a conversion kit so you’d have a full hydro setup, but he’s closing up shop and all his kits are gone now. you’ll have to make your own setup id imagine if you wanna go full hydro, otherwise they make conversion kits for it.
Ricextacy
Mar 31, 2010 09:04 PM
EF9_RIDER37
Oct 15, 2009 09:10 PM
tfeagley
Mar 15, 2009 11:18 AM
dokdok
Welding / Fabrication
Jan 26, 2009 01:22 AM
