No dash lights/illumination - 1990
Old Jan 31, 2022 | 06:28 AM
blackbird307's Avatar
Default No dash lights/illumination - 1990
Hello everyone,
I am struggling with a problem on my 1990 accord where the dash lights don't go on when you turn on headlights. The combination turn switch on steering wheel activates and responds when switched. However I still don't have lights. Right on the dash there appears to be some sort of dial which I believe to be the dimmer switch. I am reading 12V on "BAT" pin of switch, when jumping BAT with O/P (output) nothing happens. Dash is still not illuminated even though there is power at the switch, and bypassing the switch does not illuminate the dash. Checked all fuses. No blown fuses..
Not all lights are out, the shifter sport mode is illuminated when activated HOWEVER. When turning switch at end of turn signal combination stick, these lights that are illuminated normally turn off when headlights are on. But the majority of the lights are off no matter what position the switch is in.
Does anyone have an idea what to test next? Where can I get some wiring diagrams?
Thanks again,
92VXeg
Oct 17, 2010 05:26 PM
z6hatchboy
Apr 22, 2008 06:50 PM
italianchooch88
Feb 13, 2008 01:45 PM
7808
Dec 18, 2005 06:50 PM
Jonathan_ED3
11
Aug 25, 2005 03:47 PM
