Not starting WEIRD electrical Problem
Old Jan 29, 2022 | 10:59 AM
Accord2006ex's Avatar
Default Not starting WEIRD electrical Problem
The main thing is that my 2006 Accord Ex won't start. When I open the door, the speedometer and tach lights illuminate on the dash. I put the key in and they get brighter. When I turn the key to ON, absolutely nothing. No engine light, no oil light, nothing else. And when I turn the key to start, nothing at all changes: Does not try to start, no clicking, the lights on the dash don't change except that the speedometer and tach lights time out and fade. It has a brand new battery and cables, a new ignition switch, no fuses are blown, and I'm out of ideas...
HELP!!!
Old Jan 29, 2022 | 07:28 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Not starting WEIRD electrical Problem
May be an issue with the starter.
Old Jan 30, 2022 | 10:16 AM
Would have thought that except none of the lights turn on when I put the key in the ON position. Found a thread that indicated it may be a grounding problem: https://www.hondaaccordforum.com/for...y-light-65447/
Old Feb 1, 2022 | 02:04 AM
SOLVED! I wasted time not properly troubleshooting, but I found it.
Since the dash only had the tach and speedometer lights when I put the key in, but none of the other lights when I turned to ON or Start, I should have checked the big white wire (power to the ignition) first. Of course there was no power to it. The next stop should have been the fuses. I DID check the fuses under the hood, all EXCEPT for the No. 23 big 50/50 amp fuse under the hood which, of course, was the IGN fuse. Yup, blown. And because of a bad starter. Anyway that's it: Bad fuse caused by a bad starter.
Old Feb 1, 2022 | 02:05 AM
You were right in what caused the symptom!
scott kish
Oct 2, 2019 08:14 AM
Dollabill$
May 10, 2019 05:33 AM
661rex89si
May 30, 2011 10:56 AM
Throwback23
Mar 18, 2011 06:52 PM
A_Vigor
Acura TL, RL & ZDX
Mar 16, 2008 04:24 PM
