Civic ef 1990 cluster revoval
Old Jan 28, 2022 | 03:06 PM
binequebec's Avatar
Default Civic ef 1990 cluster revoval
Hey wikihonda moped
I need some backup advice seriously please how to removed my cluster from my civic 1990 DX.
The job is underway and got on hold to not break anything.The 2 philips screws under the defrost button and coin pocket are removed.NOW WHAT ARE THE NEXT STEPS IN DETAILS PLZ
Old Jan 31, 2022 | 04:42 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Civic ef 1990 cluster revoval
Four screws hold the bezel into the dash - sounds like you've already removed 2 of them. Remove the other 2.
Pop the 2 screw covers off the plate that covers the back of the gauge cluster. Use a stubby screwdriver to remove the 2 screws there, then remove the plate. This will give you access to be able to disconnect the electrical connectors and speedometer cable from the back of the cluster.
Remove the 4 screws holding the cluster to the brackets in the dash. Lower the steering column, then pull the cluster out.
JustEFit
Dec 24, 2012 03:55 PM
thorclark
Oct 14, 2009 02:34 PM
Propulsion
Aug 11, 2004 12:48 PM
