H22a1 400 whp +
today I ask the tech world a simple question,
what do I need to do to my h22a1 engine to make it push 400whp + on a dyno?
drop in mahle golds with arp head stud kit, that's all I can think of, if anything else please feel free to drop a comment
Mahle golds are met with very, very mixed success. 80% of what I've seen ends up in an expensive disaster. Full sleeve + proper pistons is the only way to be sure it's reliable.
Nippon Racing makes cast turbo/nitrous pistons made from a more suitable alloy for that sort of thing. Compatible with stock sleeves. Rated for 350 but have been pushed much higher with a lot of success. They only come in Type-S spec, 11:1, so hope you have a good manifold and knock resistant fuel available if you go that route.
I ran a cast piston in NA h22 that wasnt OEM, it swelled up and essentially melted to the cylinder walls. It was a high compression motor and ripped.... for a minute. I would sleeve a H22 if I were going that route again.
Cast shouldn't swell noticeably under normal circumstances. You may have been running it lean and gotten too much heat into it.
I too recommend the sleeving route though. It's the only way to make it properly reliable for high horsepower.
*Boostwerks*
Apr 3, 2004 11:20 PM
Misfit
Nov 8, 2001 04:40 PM
