Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Loose Master Cylinder Cap?
Old Jan 24, 2022 | 03:13 PM
Honda-Civic-Runner's Avatar
5 Year Member
Loved
Default Loose Master Cylinder Cap?
Hey, so i had a scary experience today.
I had my BRAKE light pop up in my interior dash for the last few days. i didnt think nothing much of it. I thought perhaps my sensor was broken but it seems that my Master Cylinder was low in Brake Fluid.
One thing i noticed, was the master cylinder cap was loose. 2 months ago, I changed everything in the rear brakes including the wheel cylinders. I filled the Master Cylinder to the top.
Now it was low.
Before i go crazy and start taking off all the wheels and checking the drums and lines for leaks. Do you think its possible that a loose Master Cylinder cap could cause a low amount of brake fluid? Does brake fluid tend to evaporate quickly?
When i looked around the master cylinder cap area i did not see any oily fluid residue. Everything seemed pretty dry. Not sure if it emptied a month ago and within a month time frame it evaporated and doesnt show.
If i should still be seeing fluid then i guess the issue might be brake lines, inside the drums or calipers.
I just dont want to have to do all the heavy lifting of checking everything.. im hoping it was just the cap.
But if someone with experience knows what i should do next or what it could be then that would be great.
Old Jan 25, 2022 | 09:30 AM
Ryanthegreat1's Avatar
Default Re: Loose Master Cylinder Cap?
Brake fluid doesn't evaporate.
Refill and monitor. Likely it is leaky wheel cylinders.
Akuracy
Oct 26, 2021 05:59 PM
Jim Pivonka
10
Aug 11, 2014 06:02 PM
PhilE2212
Nov 2, 2012 08:26 PM
JJexpress
Apr 4, 2009 07:22 PM
mattmw88
Mar 31, 2008 06:08 PM
