So I did this silly "deep cleaning" for my 2014 accord, and they used steam to clean the floor and the interior, after that the door ajar on the panel started flickering (only one door, the front passenger one), suddenly when I am driving it turns off that is when I thought it might be a glitch then it turned back flickering.
It is definitely not the the door switch because I swapped it with other door's switch and the problem was persisted, so the switch seems OK, even when I completely remove the door switch it still flickers.
The dome lights are of course on and off so do the alarm.
Hi!
I have sorted out this kind of issue before, check
under dash fuse box for loose connectors, or switch off, remove All connectors one by one,see if any
moisture formed, and fix back all hearing the clicks.hope this helps.
So thankful for your response!
so I took it to Honda and guess what! Turned out there’s a shorted wire under the door’s floor panel! How why when No idea bit so far its ok and issue seems resolved!
so happy my accord is not going crazy anymore
