Help 02 Accord c102 plug difference
Old Jan 24, 2022 | 08:45 AM
Smokeymcweedii's Avatar
Default Help 02 Accord c102 plug difference
Help I'm doing a auto to manual swap on a 2.3 VTEC in a 4dr sedan. Everythings gone smooth I built the under dash wire harness to include all the proper plugs for the swap. That went pretty well but I was installing the motor yesterday and noticed the c102 (maybe c101) plugs are different one is square and one is rectangle. I used the motor harness from my donor car. 01 Accord coupe. The body harness has I believe 12 pins and the motor harness has 8 or 10. Most of the wires I can match up. Just have one rouge yellow one on the engine side, this is the 2 grey plugs under the hood fuse box. The one plugged in just fine. I can get pictures if needed. Any help? Please last step before I can start and check gauges and everything. This is also the family car for the gf I want it done as proper as possible. (this is complete swap from donor. Motor trans and all of the dash/engine harnesses from donor car)
Old Jan 24, 2022 | 09:27 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Help 02 Accord c102 plug difference
Here is the pin-out:
Old Jan 24, 2022 | 10:04 AM
Thank you I looked everywhere couldn't seem to find it. Apparently I have a non ulev mt and iknow the auto was ulev. Any ideas on repining them. Or should I just go salvage that other section of harness from the donor
Cory Chagolla
May 8, 2020 10:21 PM
spddeamon
Jun 20, 2010 01:19 PM
belex202
Acura TL, RL & ZDX
Dec 9, 2009 11:28 AM
96TightAccord
Jan 26, 2009 04:44 PM
