04 accord clutch locks up when trans is mounted
Hi all I have an 04 accord with the 4cyl 5 speed the clutch went out so I have tore it down all the way to the clutch. I took the old clutch out put the new one in aligned it, the transmission slides up and mounts, but when I try turning the crank with a rachet it will not turn the hubs or flywheel. I’m not giving it a lot of force as I don’t want to break anything, but if I drop the trans back off, the crank will turn fine with the clutch mounted up but not when I put the trans back up to the motor. I’ve tried changing gears and it doesn’t seem to do anything to release the flywheel or hubs. I’d appreciate any remedy y’all have thank you!
albert butterbikini
Oct 10, 2001 10:49 PM
