Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2008 Honda Civic only heats properly right side of steering wheel
Old Jan 22, 2022 | 04:12 PM
JDawg4721's Avatar
Default 2008 Honda Civic only heats properly right side of steering wheel
Hello, was wondering if anyone had any advice or have heard of this problem before. I have a 2008 Honda Civic with 120 thousand kilometres on it so it’s relatively new. The vent near the door blows hot air, the one to the right of the steering wheel blows warmish air, still warmer then the passenger side, the passenger side gets to maybe 0 degrees, (I live in a cold province) so it’s good enough to keep me alive. I’ve checked the heating core and it’s seems to be working properly, the car blows air very well so the vents seem to be doing there job. I’ve checked both actuators and they are moving when I change the air settings. I’m really at a loss here, I have no idea. Maybe it’s a damper door that is stuck on the inside of the dash? Taking any suggestions before I take it in, thanks!
Old Jan 22, 2022 | 04:53 PM
Ryanthegreat1's Avatar
Default Re: 2008 Honda Civic only heats properly right side of steering wheel
Does your trim level have the dual climate control? Where you can select a temperature for each side of the vehicle?
Old Jan 22, 2022 | 05:05 PM
JDawg4721's Avatar
no the vehicle does not have duel climate control
Old Jan 23, 2022 | 02:59 AM
Chrisfrom1986's Avatar
It doesn't get as cold here, only 32°F, but my 07 doesn't blow hot air at the higher fan speeds at operating temp. I usually only turn it on half way. Takes a long time to warm up and defrost the window.
Kilohead36
Feb 2, 2004 05:07 AM
GreenBean
14
Jan 25, 2004 05:04 PM
espanol
Nov 1, 2002 08:00 AM
