Please help I have 2002 Honda Accord coupe
Old Jan 17, 2022 | 05:31 PM
Jordanallan0731's Avatar
Default Please help I have 2002 Honda Accord coupe
So the problem is I have no blinkers or hazards unless I turn on the hazards then the blinker will turn on but stay solid and I have to manually blink the blinker also if you leave the hazards button on and turn the key off in the ignition the car stays running until I turn the hazards off I have been through all the wiring with a test light and changed the blinker relay twice and replaced every fuse in the car it’s been in 3 shops and no body can figure it out
Old Jul 1, 2022 | 05:41 AM
bmoorex5's Avatar
Default Re: Please help I have 2002 Honda Accord coupe
Have you changed the clock? 98-00 have a white piece on them and will not work with 01-02. Mine stayed on with the wrong clock installed
Old Jul 1, 2022 | 08:06 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Likely a short in the driver's side fuse/relay box or wire harness.
Do not turn the ignition switch on, what happens if you just press the hazard button?
dg3098
Jul 29, 2021 02:18 PM
90accordricer
Aug 4, 2012 10:16 PM
mcbeats
Sep 21, 2009 10:50 PM
dashman
Aug 26, 2009 03:17 PM
rhughes
Oct 24, 2005 12:11 PM
