Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2005 civic k20z3 swap
Old Jan 16, 2022 | 11:23 PM
00Skylineguy's Avatar
Default 2005 civic k20z3 swap
So i am about to swap a k20z3 in to my 2005 civic i have the complete block and internals and need a better list of parts this is what i have
6 spd lsd
rrb-a12 (RSX type s) ecu
engine harness
axels with half shaft
shifter cables
shifter box
ac compressor
rbc intake
engine mount kit
water pump
coil packs
spark plugs
Old Jan 17, 2022 | 08:01 AM
Ryanthegreat1's Avatar
Default Re: 2005 civic k20z3 swap
Don't forget the charge harness.
Old Jan 17, 2022 | 07:34 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You will also need a conversion harness, EP3/RSX cradle, EP3 radiator and fans, RSX-S throttle cable and make sure that the axles that you have are either base RSX or EP3. Also, check your A/C Compressor and verify that the plug style is the same as what is found in your chassis.
Gamaliel Ortiz
K Series
Dec 24, 2020 06:18 AM
rossi1
Aug 29, 2011 07:53 AM
b16a2rex
May 3, 2009 08:05 AM
ken-e
Mar 3, 2009 12:12 PM
