Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Intermittent speedometer
Old Jan 16, 2022 | 05:46 PM
xilef's Avatar
Default Intermittent speedometer
Hello Honda techs!
I have a 2006 Civic DX, automatic transmission, 80k miles. The speedometer works for the first 5-10 minutes of driving, then the needle drops to zero. The OBD scanner reflects correctly for the VSS in live scanning mode, even if the speedometer needle dropped to zero mph. I'm curious as to the cause.
Thank you!
Old Jan 16, 2022 | 05:52 PM
Ryanthegreat1's Avatar
Default Re: Intermittent speedometer
Failed solder joint in the cluster would be my vote.
Second most likely cause would be the driver/motor that moves the needle has gone bad.
Easy fix, junk yard replacement cluster.
lagunatic
Classic Hondas
Nov 7, 2023 09:39 AM
fourniro
Apr 9, 2018 08:15 PM
jamal
Aug 21, 2004 03:14 PM
swdubs
Jun 19, 2004 09:23 PM
