95 civic ex 1.6 fuel filter location
My sons car is sputtering when he pushes on the gas to hard, we replaced the intake filter now we wanna try changing fuel filter and if that dont work maybe fuel injectors next ??
Check ignition timing the distributor may not be timed.
Check mechanical timing the timing belt may have slipped.
Make sure there is no check engine codes.
You can remove the fuel injectors and send them to a shop that flow tests and cleans injectors, its around $10 a injector.
Its located right by the battery on the fire wall. The line should run directly to the fuel rail.
You were talking about replacing the injectors, which would mean pulling them out or were you going to pay someone to do this (a shop)?
Ignition timing is checked with a timing light. I suggest you get a shop manual (helm's manual) for the car. Worst case value, get a haynes manual. Not nearly as detailed or accurate as the Helm's manual but it will get you started and show you how to do some basic things like ignition timing etc.
i cant find the manual ur talking about all i see is Chilton and Haynes books ?
Go to auto zone or a auto store they sell the manuals.
You tube has tons of videos showing how to do it just search it.
Worry about the injectors after you have checked the ignition timing and check the mechanical timing, Look to see if the timing belt slipped and moved.
Nope. Just open it up the lines, then remove the bracket that secures it, install the new one and reverse your steps. Give the car some time before you crank it... allow the spilled fuel to evaporate. Finally, key on to check for leaks... cycle the key from off to on two or three times. If the inlet and outlet fittings stay dry... you are good to crank. If not, re-check your fittings. Repeat.
A fair amount of fuel (the full filter's worth) is likely to come out when you remove the bottom hard line. You can use a catch pan underneath, wrap a rag around the filter to minimize spray/dripping, have a large zip-lock bag ready to put around the filter when the fittings are removed, etc., to try to reduce how much fuel gets everywhere.
Yes. You're giving the spilled fuel time to evaporate so it does not catch fire, and so that you can see any fresh fuel (indicating a leak) when you cycle the pump on and off before cranking.
Looks like Helm (www.helminc.com) no longer offers the service manual for sale. Probably because it was heavily pirated over the last 30 years. With a little digging I bet you can find a website that has a copy of the "92-95 Civic Factory Service Manual" that you can download.
