H22 All motor build questions
Old Jan 16, 2022 | 11:16 AM
Cd5Frankie's Avatar
Default H22 All motor build questions
Currently have a H22A(JDM Black Top) swapped 97 Accord, and I was looking for what the best engine internals to run and what performance parts should help ,me reach that goal, because im trying to reach 300-400 HP all motor. A list would help so much and should I have the motor re-sleeved.
Old Jan 22, 2022 | 02:57 PM
AndyD's Avatar
Default Re: H22 All motor build questions
It's been awhile since I last looked into H22 builds but I doubt much has changed. 300 WHP is possible but will be pretty difficult to achieve.
Your best bet would be to reach out to a user by the name of 98vtec. He hasn't been on this site for a while but he used to build H22s. He had his own company. His name is Blake if I remember correctly. He lived in FL, and I assume still does.
If 300-400WHP is your goal, I would say a K24 swap would be cheaper and more realistic.
This is a thread you might want to check out, too.
https://honda-tech.com/forums/all-mo...eader-2987492/
Old Jan 22, 2022 | 08:55 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
300 wheel HP on a street driven H22 is a really difficult task... I have thrown the kitchen sink at mine and have only reached 244 wheel HP on pump gas. A true CNC'd cylinder head would probably net me another 15 or so HP... so now I am scaring the hell out of 260 wheel HP. So, now what ?
Old Jan 23, 2022 | 08:47 AM
Cd5Frankie's Avatar
So what I got is 250 would be more reasonable and achievable?
Old Jan 23, 2022 | 08:35 PM
JRCivic1's Avatar
10 Year Member
Community Builder
You are getting more reasonable.
Old Jan 24, 2022 | 12:42 PM
GhostAccord's Avatar
Swap in a J35/J37 and you are already above your 250 mark.
Old Jan 25, 2022 | 06:53 AM
AllMtrRex's Avatar
Made 320whp on VP M5. 90 x 95, 14:1 cr, CNC head and Pro 3's, Custom sheet metal intake manifold, and custom header. This was 8 years ago. 280-300whp may be possible on e85 but it will not be a great street-able powerband. Most 4 cylinder NA engines making 300whp are designed for peak power/drag racing.
Old Jan 25, 2022 | 05:59 PM
Cd5Frankie's Avatar
Can I swap f22b2 fuel rail onto h22 or should I just swap fuel lines, only asking because i still have the f22 fuel rail would save the couple buck but if I can’t then it’s fine.
Old Jan 26, 2022 | 04:33 AM
You will need to swap the lines, the F22B2 rail doesn't fit the H22 intake manifold.
Old Jan 26, 2022 | 07:26 AM
Cd5Frankie's Avatar
Okay thank you, btw on the clutch line what can I do I really don’t want to do a hard line on the firewall lol, if theres even way to get around it lol. Cause I know I can just swap from a manual cd5 but like I said I want to know if theres and eaier route, not too worried about pricing either.
Old Jan 26, 2022 | 09:29 AM
In my opinion, the easiest and best rout is to use hard lines as much as you can. Only need a braided line for flex between the chassis and the transmission. But that's just me!
Old Jun 12, 2022 | 11:36 AM
nus_dogg's Avatar
I know I'm a little late, but you can use your stock fuel line and it'll reach the H22 fuel rail no problem if your H22 rail is feeding from the driverside.
​​​​Just run a clutch braided kit for the 94-97 Accord. That's on my to do list in the near future, so I can clean up the clutch dampener off the engine bay wall. Bending the lines to the exact OE and location is PITA! LOL. I know this because I just did an ABS delete with a 40/40 prop valve and I had to re-do all new lines in copper nickel lines for the front. Hated bending them even though they're easier to bend than steel lines.
dezmun0397
Jun 30, 2012 08:26 AM
belz513
Nov 30, 2005 08:49 AM
accord-25
Feb 7, 2005 04:09 PM
