Honda Accord Revs On It's Own & Heats Up Fast!
Old Jan 11, 2022 | 02:17 PM
Love My Hondas's Avatar
Icon4 Honda Accord Revs On It's Own & Heats Up Fast!
I have a 1997 Honda Accord EX with automatic tranny that has just taken to revving somewhere between 1 and 2.5 RPM's while in Park or Neutral on it's own. Recently, I noticed when I'd shut the engine off that it sounded as if the cooling fan turned off right away, then came back on, shut off and came back on, again...then shut off for the final time. I thought this pretty odd. The next time I went to start my car in the cold weather, it started normally, then suddenly began to rev between 1 & 2.5 RPM's on it's own. I shifted into Reverse and it stopped revving. When I shifted into any of the other "Drive" positions, it acted fine, but in Park and Neutral it started revving, again. After about 10 minutes, I noticed the temperature gauge was in the "danger" zone, too. Thought it might be the water pump, but can't find anything to support this theory. Please...can I get ideas???
Old Jan 12, 2022 | 01:44 PM
Loaded Butane's Avatar
Default Re: Honda Accord Revs On It's Own & Heats Up Fast!
I know the cooling system needing bled can make the RPMs jump up and down. With it overheating as well the first thing I would do is bleed the coolant with the bleed screw by the thermostat.
Old Jan 13, 2022 | 08:47 AM
Icon4 Re: Honda Accord Revs On It's Own & Heats Up Fast!
Thanks SO much...that's exactly the information I needed!
Randy Stehouwer
Aug 14, 2019 02:31 PM
ThatCarFellow
Sep 12, 2018 08:20 AM
Ahmed El-naser
Apr 20, 2016 08:31 PM
hwright
May 15, 2013 03:50 PM
kkzk70
Apr 6, 2006 06:11 AM
