Am I Missing Grounds?
Old Jan 9, 2022 | 10:45 AM
4g4dcruisin's Avatar
Default Am I Missing Grounds?
96 civic.
i don’t see anything grounded near the thermo. Am I missing something?
all stock by the way.
Old Jan 9, 2022 | 04:16 PM
punk0mi's Avatar
5 Year Member
Loved
Community Favorite
Default Re: Am I Missing Grounds?
There should be a ground on the thermostat housing. I don't really see that one from the pictures.
Old Jan 9, 2022 | 04:22 PM
I didn’t see one either. No place for one when I’m looking.
Old Jan 9, 2022 | 04:26 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
It depends on the Civic trim. Some Civics have ground G101 under the air filter housing.
Old Jan 9, 2022 | 04:37 PM
I have an LX, and there IS a ground under the air box. The filter housing would be under the intake and I haven’t looked there.
Car DOES start and run. Tho I do have an intermittent problem with the fuel pump priming and main relay clicking.
Old Jan 9, 2022 | 04:44 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The air box is the air filter housing. So, that is ground G101.
Old Jan 9, 2022 | 04:46 PM
so I’d need to take off the top portion of the filter housing or the entire piece going into the intake?
i have the type of intake where the filter mounts on top.
Old Jan 9, 2022 | 04:49 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
There is nothing to take off, if you see that ground is there and secured.
Old Jan 9, 2022 | 04:51 PM
I’ll have to check it out tomorrow, no light right now. Would it be a chassis to manifold type ground?
Old Jan 9, 2022 | 10:35 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
No, the engine harness would be connected to that location.
Kei-EF8
Appearance Build Threads
67
Sep 15, 2013 10:28 PM
mr.compton
Nov 12, 2005 12:43 AM
JerkzEm1
May 1, 2005 07:02 AM
lilbluturtle34
Aug 3, 2004 02:23 PM
