Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2009 Accord Sedan Front Door Stuck Closed
Old Jan 2, 2022 | 07:29 AM
philw12's Avatar
Default 2009 Accord Sedan Front Door Stuck Closed
Hey all:
I took the front passenger door panel off the other day to change out the arm rest. When I put the door panel back on, the door lock switch above the interior handle is stuck in the "unlock" position and I can't get the door to open. This is what I have done to try to get the door to open:
_
  • The lock switch on the door is physically stuck in the unlock position.
  • The interior and exterior handle open and close all the way normally, but do not open the door.
  • The lock / unlock button on the drivers door works on the three other doors correctly. It does not move the switch on the stuck door.
  • I tried unhooking the battery and unlocking the door / opening the door. It didn't work.
  • I removed the two screws holding the interior door handle in place and removed the handle assembly as far as I could. there does not appear to be anything blocking the switch from moving from the inside.
If I can just get the door open, I can remove the panel and figure out what is going on with the cables / door lock actuator / latch. I cannot remove the interior door panel with the door closed.
Does anyone know how to get the door open when it is stuck closed like this??
Thanks, Phil
Old Jan 2, 2022 | 12:57 PM
Eugene1979's Avatar
Default Re: 2009 Accord Sedan Front Door Stuck Closed
https://www.hondaaccordforum.com/for...nt-open-55044/
Steve40th
Honda CR-V & Element
Nov 8, 2019 06:12 AM
JDMEK108
Jun 14, 2010 01:07 PM
Tarlacon
Dec 14, 2008 03:54 AM
BB4
Aug 18, 2005 03:39 PM
