Clanking inside Del Sol steering wheel
I started noticing a sound like a plastic piece clanking around inside my steering wheel.
the sound comes up every time I turn the wheel a full rotation or more, and it sounds like whatever it is is being tossed around. Has anyone had this before?
I can’t quite tell if it’s coming from inside the steering column cover, or the airbag area/inside the steering wheel itself
It is a safety plug end to be used when you are removing the air bag or cable reel... it should snap on to the lower plastic trim panel that you removed.
duh blacksheep
Oct 21, 2004 04:27 PM
