91 Accord passenger blinkers dont blink but hazards work fine.
Old Dec 26, 2021 | 08:14 PM
grooven12's Avatar
Default 91 Accord passenger blinkers dont blink but hazards work fine.
SO, i've done the fuse thats tucked away under the kick panel, did the blinker stalk, cant get a hazard switch for this car where im at but i figure since when i poke the button all my lights flash normally it oughta be alright, no sound comes from the relay when i try to use my passenger blinkers. i am at a loss.all the bulbs are fine as well.
Old Dec 27, 2021 | 07:12 PM
914lps's Avatar
Default Re: 91 Accord passenger blinkers dont blink but hazards work fine.
By "passenger blinkers" do you mean your turn signals?
If they flash when your hazard lights are on I would suspect the trunk signal switch. Have you tried by passing the switch to see if everything other then the switch works? Have you put a Metter on the switch to see if it had power? If it is completing the circuit when turned on?
Old Dec 27, 2021 | 08:26 PM
grooven12's Avatar
Yeah my passenger side turn signals aren't functioning. If by trunk signal switch u mean the turn signal switch yeah I've swapped it out with a brand new one to no avail. I figure the switch is fine wires all have power coming from them, tried jumping the pins in the hazard switch but that did jack squat for me but hey my hazards all work just not the passenger side when I wanna use my turn signals
grooven12
Nov 22, 2021 12:16 PM
Deeeteee
Sep 28, 2021 03:28 PM
caper666
Mar 11, 2007 12:25 PM
skiracer8148
Dec 31, 2005 05:04 AM
