anyone know what the name of this flange would be?
Old Dec 21, 2021 | 09:48 AM
rtubbz's Avatar
Default anyone know what the name of this flange would be?
cant find the dimensions on any diagrams
heres a bad diagram i made of the flange
Old Dec 21, 2021 | 10:58 AM
v6buick's Avatar
Default Re: anyone know what the name of this flange would be?
Where did you find these dimensions? Those don't seem to match anything common. Is this what you measured on a turbo?
Old Dec 22, 2021 | 07:39 PM
Dee's Avatar
Dee
Post a pic of the actual flange showing the mount holes center to center measurement with whatever you are using to measure it. Garrett T4 is 82.55mm x 69.5mm and T6 is 112.78mm x 69.85mm. Holset T5 flange is 88.9mm x 70mm. Greddy dual inlet TD07S, T78, T88 is 82.5mm x 70mm.
dual port (dual scroll is often misused too) exhaust inlet flange is what it is called.
Old Dec 23, 2021 | 05:19 PM
rtubbz's Avatar
heres a picture
Old Dec 23, 2021 | 11:45 PM
Dee's Avatar
Dee
Most likely a Borg Warner T6 flange. Are there any other markings on the housing other than the internal AR 1.34?
Old Dec 26, 2021 | 09:30 PM
TheShodan's Avatar
Moderator
Originally Posted by rtubbz
heres a picture
measurements of this please is milimeters. hard to tell from the photo alone
BlkChryKord
Welding / Fabrication
Apr 26, 2008 06:02 AM
rkeith
Mar 21, 2006 12:00 PM
zexifiedlude
Dec 29, 2005 10:19 AM
