Whiney Car and Transmission Fluid Evaporating (leaking somewhere)
Old Dec 19, 2021 | 05:47 PM
teahtime's Avatar
Default Whiney Car and Transmission Fluid Evaporating (leaking somewhere)
I've been away for awhile since my 1995 Honda Accord V6 has been holding up well until just recently. Now i have a couple of idiosyncrasies that are starting to bug me: 1) something periodically intermittently emits a high pitched whine when accelerating; and 2) transmission fluid is leaking to some 4th dimension (nothing on the ground)
Had anyone had either of these two issues? I've gone through a case of Honda ATF (and since i'm not sure where to get more) so I figured I should see if anyone has any ideas on the above two items and where to get the Honda ATF at a good price.
Thanks in advance for any thoughts (and yes the car still leaks oil)
-Teah
Old Dec 30, 2021 | 08:42 PM
teahtime's Avatar
Default Re: Whiney Car and Transmission Fluid Evaporating (leaking somewhere)
Update: Still do not know where the transmission fluid leak may be, but i do have transmission fluid. I called a local dealer and their price was about as good as I could get on Amazon and they had it in stock. So, if you need the transmission fluid, call and ask the price. I was pleasantly surprised that each quart was ~$9.
Old Sep 29, 2022 | 10:19 PM
teahtime's Avatar
So, i have been living with the leaky transmission and i finally ran out of the case of transmission fluid i purchased. The fluid finally started showing up on the ground, but outboard of the transmission. we are trying to replace the transaxle seals, we'll see if this works.
Old Sep 30, 2022 | 07:24 AM
Gds80's Avatar
Any good news on this?
Old Oct 19, 2022 | 10:44 AM
teahtime's Avatar
[update] we replaced the seals and so far, no leak. but we now have other issues (P0730 code)
Gadgetball
Transmission & Drivetrain
Jan 25, 2021 05:10 AM
Cropgun
Feb 28, 2017 08:56 AM
sjala76
Mar 19, 2013 08:08 PM
buffet_fan2002
Apr 10, 2012 06:47 AM
Jbrown
Aug 9, 2008 09:34 PM
