Fuse 31 PGM-FI,ECM/PCM & Integrated control unit .
Hey guys I’m new here.
(CIVIC EK96)
I went to test the fuse box the other day when my car couldn’t start , checked it with *test light* and tested it on
{*FUSE 31* PGM-FI Main Relay, Powertrain/Engine Control Module (PCM/ECM), Integrated Control Unit}
There is no voltage on this fuse, I’ve changed fuse and yet still no power .
I thought the fuse was blown but I removed the fuse and tested the port, the test light won’t light up too and I tried using the fuse on *FUSE 31* to other port it works fine ..
Is something wrong here or it should be the way it is on FUSE 31?
