Unknown part leaking oil by oil pan
Old Dec 18, 2021 | 01:21 AM
cfromtx's Avatar
Default Unknown part leaking oil by oil pan
So I want to know what this part is. I’ve looked in the manual and online / YouTube. But it looks like it’s leaking bad from that area. It’s connected to a belt, and it’s on the driver side, below the timing belt cover. Obviously my oil pan is leaking but I’m curious on the area in the circle. Thank you !
Old Dec 18, 2021 | 10:48 PM
cfromtx's Avatar
Default Re: Unknown part leaking oil by oil pan
Nvm guys it is my ac compressor lol I guess the leak is from above. Time to investigate!
Old Dec 20, 2021 | 04:19 AM
DaX's Avatar
DaX
Loved
Community Favorite
Does your car have power steering? The shaft seal can go bad in the power power steering pump and make a mess of things underneath it. Other sources could be valve cover gasket and the cam seal.
I recommend taking your time and cleaning everything up really good, then running it and seeing if you can identify the leak source.
Old Dec 20, 2021 | 02:37 PM
Efmysedan's Avatar
Isn’t ac fluid neon green or some type of color bc of the dye that helps you see leaks.. take a paper towel to it I bet it’s pinkish so ps fluid.
Old Dec 20, 2021 | 03:46 PM
DaX's Avatar
DaX
Loved
Community Favorite
depends on whether or not dye was added at some point. The original systems didn't have dye. But I agree, I'm thinking PS fluid
Old Dec 20, 2021 | 05:25 PM
cfromtx's Avatar
i do need to change a bunch of gaskets and covers cause the person that had it before me. Used some of that orange paste to seal all of it lol sucks. But it gives me something to work on I got the oil pan gasket, valve cover with gasket, iac gasket. And after I switch that out I think I should be fine. I’ll show y’all after though! We’ll see what happens…
Old Dec 20, 2021 | 05:27 PM
cfromtx's Avatar
I have no power steering on my 91 civic. The one I got is a manual trans
jrm
Honda Civic (2001 - 2005)
May 26, 2015 07:32 PM
krieg
Jan 16, 2010 10:49 AM
1990integraGS
Nov 8, 2004 05:38 PM
mattmw88
Apr 8, 2004 08:01 PM
ID_ten_T
Feb 4, 2004 08:27 PM
