Honda Accord 2016- 2017 This is the place to discuss all things Honda Accord related for the 2016 -2017
Front passenger window issue
Old Dec 17, 2021 | 11:58 AM
sweetjew's Avatar
Default Front passenger window issue
I took my car to a body shop and shop took off the front passenger door to repaint it. After that whenever I’m trying to roll up or down the passenger front window, it moves about an inch either direction and stops. So it will take 20 times clicking window switch to roll it all the way up and the same amount of time to roll back down. I tried instructions to reset the passenger window and that did not work. Am I missing something? My car is 2016 Honda accord EX- L
Thanks in advance
Old Dec 18, 2021 | 01:35 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Front passenger window issue
This is the reset procedure, did you follow these same procedures. Regardless, you may have to try again.
Old Mar 18, 2022 | 08:39 PM
sweetjew's Avatar
Thanks. I have reset the window successfully but now the drivers window switch that controls the front passenger window does not work at all. But the passenger front window rolls down an up with the help of the front passenger door switch. I replaced the master switch on drivers door with a new one but the issue still persists.
Could it be the front passenger door main plug that goes into the outer frame of the door or bad front passenger switch wiring?
Old Mar 19, 2022 | 09:55 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Have you tried also resetting the passenger side switch too?
Old Mar 19, 2022 | 09:56 AM
sweetjew's Avatar
Not yet
But I will try that now! Thanks
BattleBun
Oct 24, 2020 06:01 AM
slipstreamvash
Feb 1, 2015 05:26 AM
autoxthis
Sep 11, 2007 10:15 PM
please.laugh
Oct 24, 2004 02:23 PM
