Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
Minimum rotor thickness for 2013 Accord Sport
Old Dec 10, 2021 | 09:57 PM
lv6l's Avatar
Default Minimum rotor thickness for 2013 Accord Sport
What is the minimum rotor thickness for 2013 Accord Sport front and rear?
Thanks.
Old Dec 11, 2021 | 01:07 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Minimum rotor thickness for 2013 Accord Sport
Replace the brake disc if the smallest measurement is less than the maximum refinishing limit.
Front Brake Disc Inspection
Standard:
NISSIN type: 25.0 mm (0.984 in)
AKEBONO type: 23.0 mm (0.906 in)
Maximum refinishing limit:
NISSIN type: 23.0 mm (0.906 in)
AKEBONO type: 21.0 mm (0.827 in)
Brake disc parallelism*: 0.015 mm (0.00059 in) max.
Rear Brake Disc Inspection
Standard:
9.0 mm (0.354 in)
8.0 mm (0.315 in)
*: This is the maximum allowable difference between the thickness measurements.
Old Dec 11, 2021 | 04:14 PM
lv6l's Avatar
Thank you very much.
Driver front is 24.70mm
Passenger front is 25.14
How much in mm is taken off when you resurface the rotors?
mvp2ny
May 18, 2021 02:15 PM
mjohnson28
Sep 19, 2020 07:16 PM
The Illest CD5
Feb 18, 2014 04:26 PM
hondatuningboi96
Feb 16, 2008 08:04 AM
