Wheels Wheels and Tires
NY SSR Comp Type C 16x7.5 4x100
Old Dec 8, 2021 | 04:51 AM
THE ITCH's Avatar
Default SSR Comp Type C 16x7.5 4x100
I have the following for sale and I can be reached at fish777@aol.com
These are Speed Star Co LTD original forged wheels from Japan. These are SSR Comp Type C 16x7.5, +42 offset, 4x100 bolt pattern. The rims will accept 12mm or 14mm bolts. This is a set of four rims with Continental Extreme Contact DW tires mounted and Road Force balanced. The tire size is 205-50 ZR16.
These rims weigh 11lbs each and the tires weigh 19 lbs each for a total of thirty lbs per corner. This was by far the best performance upgrade made to my car. I lost over fifty lbs of unstrung weight which affected acceleration, deceleration, braking, and suspension.
The tires have approximately 6000 miles of highway driving. The rims have a hand polished lip, to a mirror shine, and shows no signs of common clear coating degrading. The rims also come with center caps. The center caps currently have a stick-on Mini Logo over the SSR which can be removed if desired. All rims run true without any bends.
I have listed this as local pickup only and would prefer that. However if necessary I would help to ship at Buyers expense. Price $2650.00
Old Jan 3, 2022 | 09:30 PM
washinri's Avatar
Default Re: SSR Comp Type C 16x7.5 4x100
Hello, are the wheels still available? Where are you located?
Old Jan 10, 2022 | 02:12 AM
THE ITCH's Avatar
Yes they are still available. Thanks for the inquiry. I am in Pulaski, NY 13142. Steve
SlAmMeD 91 HaTcH
Jan 18, 2013 09:45 AM
1SiKDA8
Mar 3, 2008 06:55 PM
