Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
outer tie rod adjusment - alignment question
Old Dec 5, 2021 | 09:40 AM
Honda-Civic-Runner's Avatar
5 Year Member
Loved
Default outer tie rod adjusment - alignment question
Hi,
when i took off my outer tie rod i measured the distance and number of turns it took to take off the outer tie rods.
The thing is i may have spun it in the wrong number.. for example instead of 13 turns i might have only done 10 turns. and instead of 3" from the inner tie rod i might set it to 2.5".. (just an example)
If i take it get a wheel alignment, will they adjust that for me? What should i do at this point?
Old Dec 5, 2021 | 06:20 PM
Ryanthegreat1's Avatar
Default Re: outer tie rod adjusment - alignment question
That is part of an alignment. Get it reasonably close. If it is way out it will eat tires and drive like garbage but it will get your around the block to the shop for an alignment.
Old Dec 5, 2021 | 07:37 PM
5 Year Member
Loved
thank you very much!
RootMode
Feb 16, 2019 04:52 PM
jonyi27
Nov 20, 2012 09:23 PM
Topshot
Apr 9, 2012 07:11 PM
VTECIntegra9
Suspension & Brakes
Aug 14, 2008 02:02 PM
drumminforev
Apr 10, 2006 01:42 PM
