Rounded iacv bolt 😒
Old Dec 4, 2021 | 03:58 PM
theoryh's Avatar
Default Rounded iacv bolt 😒
Hello guys , 94 civic ex 5 speed, idles rough when cold sometimes when still warming up almost sound like it wants to stall . Wanted to clean the iacv but my top bolt is almost rounded off, can’t get a grip with vice grips.. . Any ideas to get em loose
Old Dec 4, 2021 | 05:03 PM
Ryanthegreat1's Avatar
Default Re: Rounded iacv bolt 😒
6 point 10mm socket not made of chineseium.
Old Dec 4, 2021 | 05:12 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Cut the head off the bolt, get the other bolts out, take off the iacv, then you should have space to grip the bolt and remove it. If not, tack weld a nut to the stud and then use that to extract it.
Old Dec 5, 2021 | 06:48 PM
jdblock's Avatar
You can try using a cold chisel to "unscrew" it.
Old Dec 5, 2021 | 09:51 PM
reconsiderit's Avatar
I did that to mine when removing the icav. Took a set of smaller knipex cobra to the bolt which seemed to do the trick. The hardened teeth really bite into the bolt head. Your mileage may vary depending on how stuck it is. Worst case, cut the head off, remove the icav, then remove the remainder of the bolt. Should be easier since there's no more pressure on the threads.
Almost did the same to the TB tensioner, even with a nice 6pt, standard height socket, but switched to a box wrench when I felt the socket start to slip. I've found that a pair of 10/12 and 14/17 low offset box wrenches goes a really long way on these cars. You can pick up individual snap-on, hazet, etc... wrenches that have been lightly used on ebay for 15-25 dollars.
Old Dec 7, 2021 | 04:24 AM
DaX's Avatar
DaX
Loved
Community Favorite
Remove the intake manifold from the cylinder head, then that should give you the access you need to get to the damaged bolt.
Old Dec 9, 2021 | 02:07 AM
youstolemybeer's Avatar
5 Year Member
harbor freight bolt extractor, 30 bucks well spent
rovafa2002
Apr 25, 2013 06:24 AM
iwannarace
Honda Civic (2006 - 2015)
Apr 28, 2011 07:30 AM
Accord94ex
Jun 2, 2006 07:59 PM
