PLEASE HELP!! Car cranking issue 95 civic Z6
Old Dec 3, 2021 | 12:38 PM
neoaztek12's Avatar
Default PLEASE HELP!! Car cranking issue 95 civic Z6
Hi,
im having a problem with my 95 civic, I originally thought the starter was bad because it sounded like it wasn’t engaging with the flywheel..after replacing the starter the sound was exactly the same.(as if the flywheel spins freely but the engine doesn’t turn)or if there was no compression..
the engine does crank..
the pic below is the new starter..attached is a video
any ideas?
File Type: mov
File Type: mov
File Type: mov
Old Dec 5, 2021 | 10:51 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: PLEASE HELP!! Car cranking issue 95 civic Z6
Did you make two accounts and post twice about this 95? ej1tenoch? Both ip's point to Michigan, same city too.
Since the starter is working, now you need to check compression, spark quality and fuel.
Old Dec 11, 2021 | 05:02 AM
neoaztek12's Avatar
My son made a second account, we will delete that one..
I will check compression today, then I will check timing in case the belt jumped timing for some reason..
ej1tenoch
Dec 3, 2021 12:16 PM
PnutButterCup
Jan 15, 2016 06:04 AM
cheese187
Feb 24, 2013 12:13 PM
crxblues
Sep 24, 2008 03:46 PM
Potato Man
Jun 3, 2005 02:31 AM
