Spark on alternator
Old Dec 3, 2021 | 11:59 AM
Joshuacivic88's Avatar
Default Spark on alternator
Hey guys so I have a 88 civic and I accidentally put a wrench on the alternator engine wasn’t running or anything but the radio and stuff was still on and now it just doesn’t turn on no cranks anything please help me out go easy on me too im a 17 year old trying to learn lol
Old Dec 3, 2021 | 12:09 PM
Default Re: Spark on alternator
Going to be checking fuse box and main relay once I’m out of school please guys let me know what else I should check
Old Dec 4, 2021 | 05:52 AM
Marcos Barrios's Avatar
well youve come to the right place ^_-
yea the power wire on your alternator goes right the the under hood fuse box its one of the two bigger wires that goes in there
and yes it has a fuse
now since you said that the radio was on and now nothing cranks
that tells me that you had the key in the number 2 position
witch had the fuel primed and the ecu computer on
so the ecu fuse in the under hood fuse box may very well also be popped
check these two things and then go from there
Old Dec 4, 2021 | 12:54 PM
scelestus's Avatar
Adding on to what Marcos said - the main fuse is the big one on the left in this picture. The ECU fuse should be # 7 the way this is numbered, but don't quote me on that - hopefully your cover still has the layout.
While you're in there, check the big middle fuse labeled ignition (#2 I think?). This may have blown as well as, or instead of, the main.
Mintyek
Sep 17, 2013 05:39 AM
98prelude98
Jun 2, 2005 09:12 AM
92silude
Mar 14, 2005 09:29 AM
