Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Need help finding trans mount bolt size
Old Dec 1, 2021 | 04:20 PM
Ginja Ninja's Avatar
Default Need help finding trans mount bolt size
I need to know the size of the rear left one, replacing the mount and found someone put the wrong bolt in.
2006 Honda Civic si coupe, Need to know the bolt size of the left rear trans mount bolt, thanks in advance
Last edited by Ginja Ninja; Dec 1, 2021 at 04:21 PM. Reason: Added make and model of car to post
Old Dec 1, 2021 | 07:55 PM
Ryanthegreat1's Avatar
Default Re: Need help finding trans mount bolt size
I am fairly certain a stud and nut go in that location.
https://www.hondapartsnow.com/parts-...unts_2_0l.html
https://www.hondapartsnow.com/parts-...case_2_0l.html
You can run a bolt in there, same as part 12 (90166-ST7-000) in the first link. Should be an M12x1.5 with a 64mm length.
Stud is 90380-S10-000
Nut is 90371-SEF-000
Beware you might be opening a can of worms. There is a reason the stud is missing.
Old Dec 2, 2021 | 06:05 AM
I actually called Honda and they sent me a stud, but It wasn’t long enough to thread into it. But yeah hopefully I’m not opening a can or worms but guess I’ll find out..
Old Dec 2, 2021 | 06:17 AM
The stud has a thick spot between the long side and short side that might not pass through the mount bracket.
PapiCD5
Jun 2, 2018 11:56 AM
another eg
Jun 22, 2016 09:29 AM
cticknor666
Mar 25, 2013 11:43 AM
Doeboy
Mar 22, 2007 10:24 AM
Joao
Apr 3, 2005 03:11 PM
