Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Heavy Duty Metal Protection ON EVERYTHING!?
Old Nov 30, 2021 | 07:39 AM
Honda-Civic-Runner's Avatar
5 Year Member
Loved
Default Heavy Duty Metal Protection ON EVERYTHING!?
soon i will be installing a lower control arms, steering knuckles, outer tie rods, lower ball joints for a 2007 Honda Civic LX.
I wanted to know if should do the following:
  1. Spray the knuckle, control arms, outer tie rods and lower ball joints (excluding boot) completely with "Metal Protection Spray"
  2. Spray the threads of all components with "Metal Protection Spray"
Below is a picture of the spray i want to use:
Old Nov 30, 2021 | 08:06 AM
5 Year Member
Loved
Default Re: Heavy Duty Metal Protection ON EVERYTHING!?
so im following along with this guy..
if you click and see, he is using that one brand, However its hard to find on amazon or ebay..
i am wondering if its safe to instead use "RP-342" spray over the same area the guy in the video is spraying over. thanks
Does anyone know if this spray is safe to spray over wheel bearings?.. i want to spray it in the area over the wheel bearing and snap ring... i want to coat between the bearing and hub contact point
nalley0710
Apr 24, 2013 01:32 PM
frmdstryr
Aug 17, 2010 06:25 PM
NayborhoodJohnny
Nov 4, 2009 04:01 PM
fidelito
Suspension & Brakes
Jan 23, 2006 06:36 AM
curt801
Jan 10, 2006 08:58 PM
