Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Is my Accord model rare?
Old Nov 30, 2021 | 06:37 AM
hondababy45's Avatar
Default Is my Accord model rare?
Hello,
I have a 2006 Honda Accord coupe EX V6 3.0l w/ VTEC, which I know in itself isn’t rare. The thing is it has a 5 speed manual transmission. The only other 06 v6 manuals I can find are 6 speed. Is my car particularly rare? Is it possible the stock 6 speed was replaced at one point with a 5 speed? Why would someone do that?
Old Nov 30, 2021 | 09:13 AM
hondamark35's Avatar
Default Re: Is my Accord model rare?
You have a 4cyl with a V6 decal added to the trunk, or a 6-speed with a 5-speed shift ****. either scenario would have taken a few minutes and zero to not-many bucks to make happen.
It wouldn't be cheap or easy so I wouldn't count on it but adapter plates are available to bolt up a 5-speed from the 4cyl. the purpose is typically to allow for an AWD conversion. you can have a look and see if there is a 1/2" plate between the transmission and engine block or a driveshaft running to the rear axle.
search your VIN. that will tell you what you should have.
Old Dec 1, 2021 | 02:49 AM
We’ll it’s definitely not the first scenario because it drives like a V6, I would’ve noticed immediately if it were a 4 cylinder. The second seems unlikely because wouldn’t reverse be 6th gear? I don’t have awd and the vin says it’s a 5 speed v6.
Old Dec 1, 2021 | 03:03 AM
sorry the vin does pull up that it’s a 6 speed. Is it possible the transmission went out and it was cheaper to replace it with a 5 speed? Don’t see how it’s possible for a 6 speed to have a 5 speed shifter without causing tons of issues.
Turyem2
Mar 5, 2018 08:49 PM
Hans
Dec 8, 2002 11:25 AM
rich
Mar 26, 2002 06:04 PM
