Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Door locks not working
Old Nov 29, 2021 | 09:15 PM
ek9SD's Avatar
Default Door locks not working
I'm having problems with my door locks not working. Only the drivers side door lock works when I use my key to lock or unlock the doors. Also if I use the power door lock button to lock or unlock the doors only the driver door works. I also notice when driving and the coming to a stop the door locks cycle either locking or unlocking, then when taking off again they cycle again I can audible hear it like when you press the lock/unlock button. I have checked the fuse amd it is good, but when I remove the fuse and put it back in it cycles the locks.
Old Nov 30, 2021 | 07:26 AM
Honda-Civic-Runner's Avatar
5 Year Member
Loved
Default Re: Door locks not working
im not too sure but it could probably be that water got inside the "Power Window Switch". Typically when you leave the window open when it rains, water may get in there and could cause the electrical components to go looney. but im not 100% sure.
One way would be to take out the switch and use a multimeter to test it out. (You can YouTube on how to do that -
or it could be something is wrong with the wiring.
The easiest way would probably be to find another power window switch, probably from a junk yard or buy a new one and see if it fixes the issue but then its possible that might not resolve the issue
Old Jan 15, 2022 | 03:24 PM
ek9SD's Avatar
So I tryed to do a parasitic draw test today and I connect the positive of the multimeter to the negative battery clamp and when I connect the negative of the multimeter to the negative battery terminal post I can hear the locks cycle again. Any ideas would be helpful
Old Mar 28, 2022 | 09:10 PM
ek9SD's Avatar
Anyone know how I can find a short
Old Mar 29, 2022 | 02:11 AM
rbwdriven's Avatar
Check your door plugs. My buddy had same issue and his door plug (harness) was not fully seated.
droopdog7
Honda Accord (2013 - 2015)
Apr 25, 2021 08:23 PM
whb
Oct 13, 2017 12:36 AM
John A. Parker
Apr 10, 2017 10:00 AM
nates01ex
Honda Civic (2001 - 2005)
Jun 10, 2008 07:42 PM
azgreg
Apr 9, 2008 01:04 PM
