2001 crv back to life
What's up fellas, have a crv that's been our farm truck the last 5 years. Just did b20 jdm swap and some other mods coming.
was a member on crv forum bit didn't really seem to want to help.
forum.anyway, thanks for the add
Ok, well was just introducing myself in previous post. Here's my dilemma. I bought Jdm engine and trans and got it in. Did the ckf bypass no prob (so I think)
fires right up but idle sometimes jumps up and down like from 700 to 1500.
Im wondering if maybe I have an incorrect electronic connector plugged into incorrect location, which would seem difficult to do but definitely possible as some are interchangeable.
as soon as you touch throttle it will die. I need to get this thing going so any help is appreciated. I ran codes and there was one stored for bank 1 o2 which has since been corrected. Now there are no other codes and I can't drive it. Also, fans never come on. Granted it only idles and it's 70d here but would seem they would run eventually?
help!? help you
help!? help you
Here's the deal, I never touched pedal expect when I died. Rest is just idling. Also have jdm tranny if that makes a difference.
one thing to note, I saw the speedo fluctuate today a few times while idling (as i can't drive it) I'm thinking I have harness plugged in incorrectly somewhere?
I thought vacuum leak at first but have been all through the hoses and sprayed carb cleaner. I reused most of my sensors off old motor and they were previously working.
TIA!!!
