quarter panel window trim
Old Nov 26, 2021 | 07:33 PM
1995delsol's Avatar
Default quarter panel window trim
I have a 95 integra that the quarter panel window seal/trim is starting to lift off the body, is there an after market replacement for the trim? honda shows it only with the glass and it is discontinued
Old Nov 27, 2021 | 07:11 PM
safedriver's Avatar
Default Re: quarter panel window trim
Good luck.
1994 - 2001.....E-bay = LINK $150
1996-2001 OEM new = LINK $187
I'm worried about my rubber drying out also. I think there might be a complete rubber kit for the suspension, but haven't found it.
Old Nov 28, 2021 | 01:48 PM
1995delsol's Avatar
thanks, do you know if all quarter panel glass is the same for all years, the oem one says 96-2001 will this fit early years?
Old Nov 28, 2021 | 04:59 PM
MotorMouth93's Avatar
10 Year Member
Fitment on the windows should be the same 94-01. Honda calls the old ones "blue" an the new ones "green" but they should fit.
The windows are glued in with a urethane window adhesive so you'll need to buy a tube to install the new windows. It's extremely sticky and messy so be very careful, and it's also a pain to remove, I never did it on an Integra but I have done a similar repair on my 2003 5 series quarter window.
Hard Race makes a kit that works pretty well but there isn't an OEM kit that I know of.
Old Nov 28, 2021 | 07:08 PM
1995delsol's Avatar
thanks for the info
chrisb
Paint and Body
Apr 16, 2008 06:55 PM
wood 1
Jan 5, 2007 04:10 PM
nuckingfuts
Apr 30, 2005 07:42 AM
