Turbo civic partout (Precision, AFI, tial, built motor, etc)
Old Nov 26, 2021 | 09:32 AM
Blutz3's Avatar
Default Turbo civic partout (Precision, AFI, tial, built motor, etc)
  • Selling my motor and complete turbo setup
  • This was a no-expense-spared build and has been together for over 15 years with updates along the way.
  • Can provide compression numbers soon.
  • Uses no oil.
  • Always ran brad Penn 10w40
  • B18c1Long block/ valve cover to oil pan
  • Head:4 port tapped manifold to custom oil catch
  • Honda High Pressure Valve Springs Kit includes the following: - Dual Springs - Titanium Retainers - Seat Locators - Valve Locks COMPETITION VALVES B-VTEC Exhaust FERREA COMPETITION VALVES B-VTEC IntakeTitanium intake and exhaust stud and nut kit
  • Block:
  • Wisconsin pistons 10.5:1
  • Eagle rods
  • Stock crank
  • Moroso pan
  • 6000. Can freight this or local pickup in cincinnati
  • Oem obd1 honda distributor vtec distributor for a bseries.
  • Inside is a
  • New oem honda ignition controle module
  • New oem Honda coil
  • New oem cap
  • New oem rotor
  • New oem wires
  • New gasket and oring
  • Sensors were in perfect condition
  • ​500 shipped
  • Turbo kit:Ceramic coated AFI top mount
  • Precision 5558(new w 300 miles w proof and receipts)
  • Turbo guard and ptp blanket
  • Precision 1200 hp intercooler
  • All 3 inch Ceramic coated intercooler piping with Vanjen clamp on cold side.
  • tial blow off valve
  • Everything push lock lines
  • Custom 3 inch downpipe
  • Tial 38mm wastegate Ceramic coated w screamer pipe 2800 firm you cover fees and shipping unless picked up in cincinnati
  • ID 1000s, test flowed and checked perfectly
  • Aem fuel rail
  • Aem fuel pressure regulator
  • Fuel gauge
  • 600 shipped
  • custom oil catch can setup complete with a built in coolant overflow with push-lock fitting.
  • Comes with all 6 -10 lines.
  • All redhorse fittings and braided line.
  • Valve cover is a hydrodipped art piece that pictures do no justice.
  • 550 you cover fees and shipping unless picked up in cincinnati
Old Dec 28, 2021 | 08:46 AM
Blutz3's Avatar
Default Re: Turbo civic partout (Precision, AFI, tial, built motor, etc)
Bump
Old Jul 27, 2022 | 08:55 AM
0c00l's Avatar
I know its old but is the manifold available?
Possibly more.
Old Aug 13, 2022 | 03:20 PM
Lucidsounds's Avatar
Been awhile... Is this Available?
Old Feb 6, 2023 | 06:57 PM
RoosterCake's Avatar
How much for the rail, injectors, and gague? Also is the motor still around?
jonga11
Dec 7, 2021 05:07 AM
blackeg
Aug 27, 2013 06:51 PM
Honda Bull
Appearance Build Threads
10
Apr 27, 2008 02:52 PM
Timmay
11
Jul 2, 2007 08:54 PM
