D16y8
Old Nov 22, 2021 | 08:34 AM
DentalFob9's Avatar
Default D16y8
Hello all, I recently rebuild a d16y8 out of a 2000 Civic EX. After I got the motor put back in the car and mounted up, I noticed a bag I forgot about that I got back from the machine shop with my block and head. Is this part on the inside or outside of the engine? Also, If it's on the inside is it vital to operation? Thank you for your time!
Old Nov 22, 2021 | 08:47 AM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Default Re: D16y8
It's #10 on this diagram
https://www.hondaautomotiveparts.com...k-oil-pan-sohc
Cover, Breathing Port
11311-PM3-000
I'm speculating but, without that installed, you may get excess oil in your oil breather chamber (black box near the oil filter).
Old Nov 22, 2021 | 08:49 AM
CX-Adam's Avatar
talks to himself
Community Builder
Default Re: D16y8
You might be able to drop the oil pan and install it. You can see it in this picture.
Old Nov 22, 2021 | 09:26 AM
DentalFob9's Avatar
Default Re: D16y8
​​​​​​ Awesome, thank you so much. I think I'll run it where it's at and then take it to the shop I work at and install it on the lift.
Old Nov 22, 2021 | 05:52 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: D16y8
if you have a catch can setup, that's not necessary. I didn't re-install that "diffuser" on mine.
Old Nov 23, 2021 | 09:53 AM
DentalFob9's Avatar
Default Re: D16y8
What kind of catch can did you install? Is the oil breather box in the back of the engine compartment good enough? Or are they different. Thank you for your input!
Old Nov 24, 2021 | 08:15 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: D16y8
typical 3 port cylinder catch can.
(2) 10AN bungs on the valve cover
(1) 10AN bung that replaces the black canister found underneath I/M
Apophis
Jan 21, 2009 06:46 PM
96CIVICEX
Mar 13, 2004 03:07 PM
AllMotorBrew
Oct 30, 2002 12:23 PM
