Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2004 civic EX ECU swap?
Old Nov 22, 2021 | 06:54 AM
Hooton1992's Avatar
Default 2004 civic EX ECU swap?
I have an 04 civic EX and need an ECU. Assuming I get the exact part number do I still need to swap the ignition or will it recognize the key? Are the ECUs VIN specific???
Old Nov 22, 2021 | 07:03 AM
Ryanthegreat1's Avatar
Default Re: 2004 civic EX ECU swap?
01-05 EX ECU with matching transmission will work but you will need to have the immobilizer programmed. They are not VIN specific.
Old Nov 22, 2021 | 07:06 AM
Hooton1992's Avatar
Is the dealer the only one that can program the immobilizer?
Old Nov 22, 2021 | 07:13 AM
Hooton1992's Avatar
So if I buy the ECU and the immobilizer as a set (exact part number) will that work without having to program it?
Old Nov 22, 2021 | 07:22 AM
The key that comes with the set won't work in your door or trunk locks. Otherwise yes if they were working in the car they came from the matched set should work in your car.
Locksmiths, independent repair shops, and the dealer will all be able to program the immobilizer. Locksmith and a mobile independent will be able to program in your driveway.
Old Nov 22, 2021 | 07:49 AM
Hooton1992's Avatar
Awesome! Thank you!!
Pogusone
Aug 26, 2021 03:53 AM
Tim Hitzeman
Dec 8, 2019 11:39 AM
Vtec04
Oct 4, 2016 04:49 PM
sethro
Nov 12, 2008 02:50 AM
sethro
Nov 11, 2008 03:02 AM
