Honda CR-V & Element 2WD & 4WD Element & CR-V
Can't lock/unlock driver door on 97 CRV
Old Nov 21, 2021 | 12:32 PM
OwenElderkin's Avatar
Default Can't lock/unlock driver door on 97 CRV
https://www.crvownersclub.com/threads/driver-door-doesnt-unlock-or-lock.223313/
**** will go down/up if the door is closed only, not with power lock switch. Can't unlock with key front outside tho so that's not a solution. Actuator is functioning at last enough to move a little.
The thread I attached has links to videos of me showing that the actuator is moving something, but not the rod that moves the lock ****
Thanks
Old Nov 21, 2021 | 01:14 PM
Default Re: Can't lock/unlock driver door on 97 CRV
Thanks
so just found out inside has to be pulled while power locking, but doesn't solve me not being able to use the outside key slot to lock/unlock
Xalyx
Jun 27, 2018 12:36 PM
XanderusMaximus
Dec 19, 2011 08:46 PM
Toe_Knee
Sep 15, 2008 12:37 PM
