97 Del Sol engine humming noise
Old Nov 17, 2021 | 04:48 PM
RECKLESSEKC's Avatar
Default 97 Del Sol engine humming noise
Del sol with M/T D16Y7 makes a humming noise while driving but only while in 2nd gear And very lightly in 3rd gear Does not make the noise When it is parked reved up to the RPM that it would be at in those gears with the clutch pressed in
Old Nov 22, 2021 | 03:57 PM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Default Re: 97 Del Sol engine humming noise
Probably a bad counter shaft bearing. Pretty common in the d-series trans. It's not staked into the case and tends to wear out.
I think I got a full set of bearings from gearspeed racing when I replaced mine.
delsoldriva
Jun 17, 2008 02:05 PM
hondadrvr
Nov 10, 2004 09:31 PM
yellowmonkeyboy
Feb 24, 2004 01:05 AM
