Cold and warm start issues
92 accord ex auto 308k
new ignitor, coil, cap, rotor & plugs/wires, coolant temp sensor (cheap rock auto one)
I believe I have two separate issues
first car will not start cold at all unless the etc sensor is unplugged. Let run for 30 sec to 1 min, shut off, plug sensor in and car will start fine. I tested the resistance on the sensor and it appears to be functioning correctly. My question is if I have a air bubble in the cooling system, would it cause the etc sensor to read wrong and cause the no start or do I have a different problem? No check engine light codes other than an occasional code 43 that I have been fighting.
my other issue is that when you drive the car for 15 or so minutes and shut it off it won’t start till it cools down so I need to replace the main relay. It also every once in a while bogs down when you give it gas from idle and will die (problematic when the relay is bad).
any help on these matters is appreciated
abiliojr
Dec 7, 2012 05:35 AM
