Hazards work, got no turn signals. 91 accord
Old Nov 13, 2021 | 12:52 PM
grooven12's Avatar
Default Hazards work, got no turn signals. 91 accord
I done diddly checked my fuses under the hood(91 accord) and decided to buy a new blinker stalk to be safe and still nothing. Bulbs work cause the hazards work when I did a walk around to make double extra sure. I do not hear the blinker relay going haywire when I try to use my blinkers either and I'm at a loss.
Old Nov 13, 2021 | 01:56 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Hazards work, got no turn signals. 91 accord
Check Turn Signal Fuse (7.5A) is located in the Auxiliary Fuse Holder, which is attached to the under-dash fuse/relay box.
https://honda-tech.com/forums/honda-...-dont-3223558/
Old Nov 13, 2021 | 02:11 PM
grooven12's Avatar
Sadly i just checked that fuse and it was not blown but i did replace it anyway. went ahead and took a extra peek at the hazard fuse under the hood for any breaks and it is also doing fine, still got the hazards all the way around and no blinker bois.
Old Nov 13, 2021 | 02:46 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Try this, unplug the connector to the hazard switch. With a small paper clip or wire, jump the harness connector's terminal no. 3 (Yel or Yel/wht wire) to terminal no. 9 (Grn/Wht wire). Make sure the wire colors and terminal numbers are correct.
Turn ignition switch to on position and try the turn signals. If they work, then the hazard switch is probably bad.
Old Nov 13, 2021 | 03:18 PM
grooven12's Avatar
if the hazard switch was bad wouldn't the hazards not work at all?
Old Nov 13, 2021 | 03:21 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Look at the circuit diagram, there are actually individual separate switch contacts inside the hazard switch unit. So, the hazards can still work depending on specific switches.
Old Nov 13, 2021 | 03:23 PM
grooven12's Avatar
ooooooooof okay lemme go see what i can do, if thats the case is there a work around cause im tired of hand signals if i can leave that pin in there then yay til the switch ships if thats the case
Old Nov 13, 2021 | 03:37 PM
grooven12's Avatar
upon further inspection, it is cold and dark, and honda seems to like everything being in one giant piece so is there anything else that doesnt require me to remove my whole front interior x'D
Old Nov 22, 2021 | 12:16 PM
grooven12's Avatar
alright so it's been a few days lol but I tried jumping the wires over and it didn't do anything of significance got any other tries?
AntisXP
Sep 25, 2021 05:49 PM
Joseph Whitney
Lighting
Mar 19, 2013 03:49 PM
pane93civhb
Jul 21, 2005 01:00 PM
