Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Cross threaded lower(shorter starter bolt) need help with size to recut threads
Old Nov 12, 2021 | 10:28 PM
hugh43611's Avatar
Default Cross threaded lower(shorter starter bolt) need help with size to recut threads
Does anyone know the lower bolt size so i can recut the threads on a 2008 civic ex starter? Is it m10, m9 or something else by 1.25mm or 1.5mm.
We cross threaded the lower(shorter) starter bolt.
The top(long) starter bolt went in fine, but we damaged the lower bolt/hole
Thanks, Hugh
Old Nov 22, 2021 | 09:44 AM
punkinbeck's Avatar
Default Re: Cross threaded lower(shorter starter bolt) need help with size to recut threads
I believe they are M10 1.25. You could always take it to the hardware store to double check. I think the problem with these is the end of the bolt sticks out past the bellhousing just a bit. It gets corroded, then damages the threads the entire way out..
Old Nov 22, 2021 | 09:46 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The lower bolt with the 17mm head size is a 12mm x 1.25 thread size.
george34
Mar 22, 2023 02:31 PM
Josh333
Honda Civic (2001 - 2005)
Aug 1, 2018 04:36 PM
si0385.
Dec 12, 2016 03:23 PM
S1NFUL RL1 619
Aug 27, 2008 04:25 PM
