POWER STEERING TO MANUAL RACK CONVERSION
Old Nov 10, 2021 | 07:17 AM
9DELSLOW7's Avatar
Default POWER STEERING TO MANUAL RACK CONVERSION
I have a 97 del sol vtec, I am going to convert it to a manual steering rack. Does anyone know if this will cause a check engine light to come on? I wasnt sure if the power steering is monitored by the ecm and would detect a fault if I remove the power rack.
Old Nov 10, 2021 | 10:04 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: POWER STEERING TO MANUAL RACK CONVERSION
It will NOT cause the "Check Engine" light to come on.
Old Nov 11, 2021 | 05:25 AM
punk0mi's Avatar
5 Year Member
Loved
Community Favorite
It won't, but make sure you cap your lines if not removing them.
Old Nov 11, 2021 | 12:03 PM
DaX's Avatar
DaX
Loved
Community Favorite
You won't get a CEL, as there are no diagnostics for power steering. The power steering system only provides an input to the ECU to increase IACV duty cycle when the high pressure side sees pressure (while turning).
bizzle2288
Aug 27, 2012 05:29 PM
L0WL1FE
Jan 12, 2012 06:38 AM
SQ is the SQUAD
Suspension & Brakes
Dec 6, 2010 10:16 AM
dru2
May 14, 2005 10:23 PM
aeolus
May 11, 2003 11:03 AM
